PCBA low leakage current
I have a high impedance PCBA design with 140V signals and I want to ensure the leakage current between traces are under 1.4 uA (100 Megohm, 10^8 ohms), mainly for crosstalk and drift. Can anyone suggest a good process for achieving this?
My PCB assembly manufacturer is currently using a water soluble flux and checking their washing process with IPC TM 650 2.3.25D ROSE Testing (Resistivity of Solvent Extract). They have another facility check their cleanliness, and per that test report it appears they consider 2 Megohm (1.56 ug/cm2 sodium chloride equivalent) acceptable and don't check past 10 Megohm (0.31 ug/cm2). That makes sense because their tester has a 60.3 Megohm maximum value. This test report shows 0.00 ug/cm2 so I'm a bit suspicious of that result.
Side question for an IPC TM 650 2.3.25 expert - the tests results are defined in units of 'ug/cm2 of sodium chloride' and in Ohms; is that really Ohm/square?
My PCB assembly manufacturer has suggested going with an Ion Chromatography analysis. I'm not familiar with that test yet so that's why I'm asking. I'm working with test house(s) to see what is recommended.
My initial research shows there are no-clean fluxes that claim SIR (Surface Insulation Resistance per IPC or Telecordia spec) well above 100 Megohm (10^11 looks typical). Would the proper no-clean flux be a better approach?
In the past I've worked on a picoamp leakage design (no solder mask, alcohol wash) so I know the leakage can get orders of magnitude less than a microamp. This design was very low volume though so we never verified the process, only the final products. Is there a middle ground for microamp leakage?
I appreciate your experience. Thanks,
Z
Z
RE: PCBA low leakage current
Have you considered a parylene overcoat?
TTFN (ta ta for now)
Parylene looks interesting. I still need to make sure I have a clean PCBA before an overcoat is applied; at least Parylene will keep out the moisture effects. Coatings may get tricky because I have opto-mechanical parts on this PCBA, and the high voltage signals pass through a cable from another PCBA (but I digress...).
Z
Googling just now found this: http://four-point-probes.com/understanding-volume-...
I expect that you already know all this, and your question was very specific to "IPC TM 650 2.3.25".
I've seen some interesting PCB design approaches inside ionization smoke detectors, where they seem to be comparing gigaohms. Quite a bit of router work to leave air gaps in the critical locations.
Military work often uses Humiseal coating to lock the traces away from the environment.
Receive the assembled boards, test them, conformally coat them with a polyurethane coating like Humiseal and ship them. Otherwise, your product will fail sporadically and what will seem like randomly until after years of torment you recognize that you still have a problem because 'environment X' still get to them.
Fix the board so that no matter how dirty it is it will work then follow the above advice. You fix it by using space where you need to, guard traces, and routed slots.
Keith Cress
The test facility recommended using the IPC TM 650 2.6.3.7 Surface Insulation Resistance (SIR) test to check for higher impedance. This is a standard test for no-clean flux processes, so if my board house can pass this test with their normal everyday (water soluble) cleaning then we are all set. If not, then things need to change...
Z
Dan - Owner
http://www.Hi-TecDesigns.com
I'm only looking for microamps of leakage, not picoamps, so this doesn't seem like 'ultra-clean' rocket science; this still is within the realm of IPC Class II. This is a single source part so these are the vendors I'm stuck with.
Did I mention my management loves to outsource as much processing (i.e. cleaning) and assembly as possible...
For the record, I talked with the test facility and the IPC TM-650 Ion Chromatography test can identify exactly what residue is left on an assembly, but it has worse resolution than the Ionic Cleanliness test for determining how much residue is left on a board. So I expect you can run an Ion Chromatography test first to determine what residue you have, and then run an Ionic Cleanliness to determine how much residue you have.
Z
Some day I'll write up my story of how we found out our preferred board house was lying to us about their capabilities...
Dan - Owner
It is very ionic and in worst cases, I have experienced several laptops, some from Apple with the failures due to corrosion from no-clean flux residue. I realize this is orders of magnitude more harsh environment but then so were the results.
I would expect issues from 100MOhm surface creepage from any airborne dust unless this is built in a class 100 clean room.
My advice is design the layout with active guarding around the critical high impedance signals and use a suitable PCB mask. ( dry or wet )
For now management says we'll continue with our current process and test as we go. Here we go...
Z
The dew point is the problem I found with all laptop products that I had fail. (Mac Air, Asus Ferrari, etc) They literally rusted in days with exposed copper. and blue dew point tags to invalidate the warranty....
