Storage Area Point Load
I am designing an elevated area for fixed storage racks. They want to use bar grating for the floor. I am adding additional structure under the rack point loads. Do I need to design the open areas for any point loads or simply the 125 psf light storage loads?
RE: Storage Area Point Load
It is a high volume tire store.
Then we've just made sure to play around with the live load distribution/skip loading on any continuous multi-span members to get maximum response.
The only equipment being used are humans and a conveyor to get the tire up there - but that is supported independently.
