Parameter mismatch in Product vs Part
This is somewhat of a follow-up to an earlier thread, but with a much more specific question.
Basically, I'm having a problem with a system parameter not updating. When I run this test script, I get a different value between the two parameters. There should not be. No matter what I do, I cannot force them to be the same.
product1.Products.Item(1).ReferenceProduct.DescriptionRef displays the correct value.
Can anyone help me figure out how to make them equal one another?
Thank you.
CODE
Sub CATMain() Set productDocument1 = CATIA.ActiveDocument Set product1 = productDocument1.Product product1.Update msgbox = product1.Products.Item(1).ReferenceProduct.DescriptionRef msgbox = product1.Products.Item(1).DescriptionRef End Sub
Thank you.
RE: Parameter mismatch in Product vs Part
I tried on a sub-assy as item(1) and for a part instance--still the same value...
I use V5R26
regards,
LWolf
The question was, "Can anyone help me figure out how to make them equal to one another"? In my parts. Not yours.
This is tied to a bug in Knowledgeware.
CODE --> WillThatWork?
--Doug
