Bounding Box Macro for Catia V5 from Mark Forbes...
Absolute great macro written by Mark.
Was wondering what line in the code needs changing so the output would be in inches and not MM.
Thanks in advance...
Script below...
Sub CATMain()
On Error Resume Next
Dim oPartDoc As PartDocument
Dim oCurrentDoc As Document
Dim oPart As Product
Dim oInertia As Inertia
Dim InputObjectType(1) As Variant
Dim Status As String
Dim oSelection As Variant
Dim bCloseDoc As Boolean
Set oCurrentDoc = CATIA.ActiveDocument
'Exclude Drawings
If Right(oCurrentDoc.Name, 4) = "wing" Then
MsgBox "This function only operates on a part or product"
Exit Sub
End If
Set oSelection = oCurrentDoc.Selection
If Right(oCurrentDoc.Name, 4) = "Part" Then
Set oPart = oCurrentDoc.Product
oSelection.Add oPart
'GoTo RunBBOpenWindow
End If
If Right(oCurrentDoc.Name, 4) = "duct" Then
bCloseDoc = True
InputObjectType(0) = "Part"
InputObjectType(1) = "Product"
oSelection.Clear
Status = oSelection.SelectElement2(InputObjectType, "Pick a Part, Escape to Cancel", False)
If Status = "Cancel" Then Exit Sub
Set oPart = oSelection.Item2(1).LeafProduct.ReferenceProduct
If oPart.Name = oCurrentDoc.Product.Name Then
bCloseDoc = False
End If
CATIA.StartCommand "open in new window"
End If
RunBBNewWindow:
Set oPart = CATIA.ActiveDocument.Product
Dim oSelection2
Set oSelection2 = CATIA.ActiveDocument.Selection
oSelection2.Add oPart
RunBBOpenWindow:
CATIA.StartCommand "Measure Inertia"
Dim xDim As String
Dim yDim As String
Dim zDim As String
xDim = oPart.Parameters.GetItem("BBLx").Value
yDim = oPart.Parameters.GetItem("BBLy").Value
zDim = oPart.Parameters.GetItem("BBLz").Value
xDim = CStr(Round(xDim, 0))
yDim = CStr(Round(yDim, 0))
zDim = CStr(Round(zDim, 0))
Dim oMatParam As Parameter
Dim sMatParam As String
Set oMatParam = oPart.Parameters.GetItem("Definition")
sMatParam = oMatParam.ValueAsString
Dim oMassParam As Parameter
Dim sMassParam As String
Set oMassParam = oPart.UserRefProperties.GetItem("PDB_MASS")
sMassParam = oMassParam.ValueAsString
If sMassParam = "" Then sMassParam = "0"
If sMassParam = "0" Then
sMassParam = ""
If Right(CATIA.ActiveDocument.Name, 4) = "Part" Then
Set oInertia = oPart.GetTechnologicalObject("Inertia")
Select Case oInertia.Density
Case 0
sMassParam = ""
Case 1000
sMassParam = ""
Case Else
sMassParam = CStr(Round(oInertia.Mass, 1))
End Select
End If
End If
CATIA.StatusBar = "Start Creating Params"
Call SetParam(oPart, "LENGTH", xDim)
Call SetParam(oPart, "WIDTH", yDim)
Call SetParam(oPart, "THICKNESS/DIAMETER", zDim)
Call SetParam(oPart, "MATERIAL", sMatParam)
Call SetParam(oPart, "MASS", sMassParam)
MsgBox "Properties Applied:" & _
vbCrLf & "LENGTH: " & xDim & _
vbCrLf & "WIDTH: " & yDim & _
vbCrLf & "THICKNESS/DIAMETER: " & zDim & _
vbCrLf & "MATERIAL: " & sMatParam & _
vbCrLf & "MASS: " & sMassParam & _
vbCrLf & "Check Results Carefully!", vbOKOnly, oPart.Name
CATIA.DisplayFileAlerts = False
CATIA.StartCommand "Save"
'CATIA.ActiveDocument.Save
CATIA.DisplayFileAlerts = True
If bCloseDoc = True Then CATIA.ActiveDocument.Close
CATIA.StatusBar = "Macro Finished"
End Sub
Sub SetParam(ByRef oPart As Product, Name As String, Value As String)
'On Error GoTo CreateParam
Dim sParam As Parameter
Err.Clear
Set sParam = oPart.UserRefProperties.GetItem(Name)
sParam.ValuateFromString CStr(Value)
'GoTo Finish
CreateParam:
oPart.UserRefProperties.CreateString Name, CStr(Value)
Finish:
End Sub
RE: Bounding Box Macro for Catia V5 from Mark Forbes...
Right underneath these sets of values:
CODE
You just need to add in these values:
CODE
'convert units from metric to imperial for box dimensions
xDim = Math.Round((xDim / 25.4), 2) & " in"
yDim = Math.Round((yDim / 25.4), 2) & " in"
zDim = Math.Round((zDim / 25.4), 2) & " in"
And you're good to go.
Bill - apologies. I checked that code in VBA, but should have run it standalone in a CATScript.
Try this. Insert this code in the same place suggested above:
CODE
xDim = (Round((xDim/25.4), 2)) '& " in"
yDim = (Round((yDim/25.4), 2)) '& " in"
zDim = (Round((zDim/25.4), 2)) '& " in"
Great bit of code.
Thanks Bill for posting and Mark for writing.
Does anyone know why the material name isn't showing? It isn't a problem but would be nice to know.
cheers
Alan
Do you have any material applied to the part?
Yes, tried a few times with different ones.
It's not an issue, I'm just trying to learn to do this stuff and wondered why.
I thought this code worked like the roughstock command giving you the minimum material size.
Unfortunately it seems to create the stock size from the inertia axis.
Still really handy though.
It looks that only works well with parts drawn in oriented XYZ axis system. For parts that has a rotation in this axis. the dimensions, are not so well optimized.
But it's a great macro
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
If you have the "core & cavity design" workbench, there is a bounding box function already implemented.
regards,
LWolf
I have seen a similar macro that gives you the option to use either the cog axis or by selecting edges to create the axis.
If I remember correctly it encoded so couldn't see how it was done.
Not having a roughstock option in the basic catia software is a bit of a joke. It should be standard.
I'll have a look
It's been very many years, I did not remember that I had put my name in the header. I don't even remember whether the PortableScriptCenter was the basis for the code, or an inspiration (most likely the former!). But I do remember that this code (as presented) has severe limitations regarding generating data that is actually useful. The only thing I really found useful was to fill in rough values on a table so they would not appear blank. Anything more than that requires actual work and thought smarty
Here's the old thread, for reference:
http://www.eng-tips.com/viewthread.cfm?qid=341826
