very high set pressure ~43500psi
I'm looking for manufacturers of PSV with set 43500 psi, can you help me?
Tx
Tx
RE: very high set pressure ~43500psi
Per ISO, only the term Safety Valve is used regardless of application or design.
https://www.rembe.com/fileadmin/produkte/prozesssi...
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
http://www.autoclave.com/products/relief_valves/rv...
met11, RVP seems a right but...
"All models are designed primarily for thermal expansion or low volume relief applications at high pressures
where flow is not critical"
my case isn't thermal expansion
Unfortunately I don't know of any other valves that can go up to that pressure. I checked the normal players (Leser, Farris, Crosby, Flowsafe, Consolidated) and none of them even get close to those pressures. Most Autoclaves that I've seen operating in those pressure ranges always have an extruder-style rupture disc, or very small safety head.
