Part selection issues in Nx9
Morning,
I have an issue in Nx9 where if I box select an assembly it will only select parts that you can see, if you turn the model after the selection you can visually see the parts that are not selected...
I have copied the \AppData\Local\Siemens\NX90 folder from a co-workers machine to replace mine to no effect.
I have also had our IT department do a fresh install of Nx9 and Nx11 on my machine, Nx11 dose not have the same issue only Nx9
Any help would be greatly appreciated.
Ian
Ian
RE: Part selection issues in Nx9
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
www.nxjournaling.com
thank you very much! I didn't even know this was an option, it was hidden in the pull down...
thanks again
Ian
