Shared-use ramp handrail
On a ramp connecting to a shared-use path, a handrail at 34-38" is needed, as is a top rail at 54" for bicyclists. A bicyclist is likely to go over a 34" handrail.
I'm looking for details on how to incorporate these requirements, along with the handrail returns at the ends of the railings. If the handrail isn't the top rail, does it need to be mounted on the inside of the posts? I take it the handrail would get a return, but not the top rail.
Thanks for any advice. I'd especially appreciate photos, details, specifications, etc.
RE: Shared-use ramp handrail
I think my question should have been: If the railing is just a handrail because of the ramp's grade, and isn't a protective rail, is the higher bike rail needed?
If a railing will also serve as protective rail because of a drop-off behind the rail, then IMHO, the bike rail is needed. The design guidance docs I have say "should," not "shall," but I can't think of a good reason not to. As they say, Murphy was an engineer.
