How to reduce residual stress in polycarbonate?
I am currently working on a project which involved a lens (injection-molded,polycarbonate). It has a lot of residual stress in it and is causing alot of problem for my optical application.
I read (from other source) that annealing will reduce the stress, and I had performed the annealing test on the lens. The lens was heat up to 135degC for 3hrs and then gradually cooled down in the oven till room temperature. I tested with my optical application and there is a lot of improvement.However, after two days, I discovered that the lens is back to its original form.
Does anyone has experience on this issue. Please advice me on this problem?
RE: How to reduce residual stress in polycarbonate?
6373,
You are not giving enough information to make an assement of the cause.  But the most common causes of molded stress are:
- Improper gate location
- Improper gate design
- Improper venting
- Improper part design
- Improper material choice
I will add, that since you are annealing the parts and the same condition is showing up days later.  The first thing I would check is that you have good gate design.  I have found the "Fan chisel gate" to work best for lenses.
Again, this is only speculation into the cause of your problem.
