IEC 60890 Temperature Rise Calculations Spreadsheet
IEC 60890 uses a series of graphs as part of the temperature rise calculations. I've been looking for either a spreadsheet, or equation to incorporate into the calculations rather than a graph.
Anyone know of a spreadsheet, or the equations used to plot the graphs?
DM
"Real world Knowledge isn't dropped from a parachute in the sky but rather acquired in tiny increments from a variety of sources including panic and curiosity."
RE: IEC 60890 Temperature Rise Calculations Spreadsheet
If there is a quicker system (but not too much complicate), I will be glad to learn
Furthermore with the data you put in the table you can plot a graph to be sure you didn't do any mistake in digitizing the data (the graph should be similar to the original one)
