SW 2001 Plus Installation prblems
For some reason, after formatting my Hard drive, , re-installing windows, and then re-installing SW 2001 Plus, I nolonger have the ability to do Drawings.  I said, ok, fine, uninstalled, re-installed, and, now, I can't do assemblies OR drawings, all I have is the part modelling ability.  Obviously there's something wrong here, what could it be?  A setting during installation that I've missed?  This is the exact same CD that I had installed Swx with before. Any ideas?
Chuck
RE: SW 2001 Plus Installation prblems
Have you set up your templates in tools\options\default\templates?
If so, then when you did a uninstall did you remove SW from your registry? If not, I would do an uninstall again and this time remove SW from your registry.
You have to be comfortable to remove data from registry because you can toast your entire computer if you delete the wrong thing.
Go to Start\Run and type Regedit and click ok.
Then go to and remove the following in bold
Reg settings to remove:
HKEY_Current_User\Software\Solidworks
HKEY_Local_Machine\Software\Solidworks
HKEY_Local_Machine\Software\Solidworks Corporation
Close and restart computer, and reinstall once your back up.
I'm currently writing an FAQ on this for everyones benefit.
I hope this helps,
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt always check the help*
