Code read UFWeight.StateType (vb)
i want to read the current "Weight Status" of the present File in NX with VB.Net.
Checling it manually, go to the Assembly-Navigator add the Column Weight Status and check the green Hook or yellow "?".
Some lines of Code:
if UFWeight.StateType.unknown = 3 then
end if
This Code will check if the Status "?" unknown is than 3.
Some more information can be read here:
https://docs.plm.automation.siemens.com/data_servi...
Can someone support me in some lines Code, how to read the actual Status of weight (UFWeight.StateType = ... value).
Thanky a lot.
Kind regards, Frank
RE: Code read UFWeight.StateType (vb)
Hi Frank,
Unfortunatly I don't have the answer
But I would like to add another question:
How to retrieve the assembly weight to place it in the parts list ?
Didier Psaltopoulos
http://www.psi-cad.fr
Hi -
You can extract the active partfile or assembly's weight(mass) by using this function:
ufs.Weight.EstabPartProps1 (pleas see net_ref.chm for further details.
Then if you run a custom program (automatic in background) every time you save, you can get the assembly weight into an attribute - which can be used in your partlist.
lklo
CODE -->
Dim wProps As NXOpen.UF.UFWeight.Properties = Nothing
    Dim wExcept() As NXOpen.UF.UFWeight.Exceptions = Nothing ' changed to array, so ufs.Weight.EstabPartProps1 can be used
    Dim weight_value As Double = 0
CODE -->
Function FindPartWeight(ByVal part_to_calculate As part)
        Try
            ufs.Weight.EstabPartProps1(thePart.Tag, 0.9, True, UFWeight.UnitsType.UnitsGm, wProps, wExcept)
            weight_value = (Format((wProps.mass) / 1000, "0.0000"))
            Return weight_value
        Catch e As Exception
            'nx("Failed: " & e.ToString)
            Return weight_value
        End Try
    End Function
Hello again,
unfortunatelly my Thread was used for a second Question and my One was not answered jet wink
So, i want to ask again:
I want to read the current "Weight Status" of the Workpart in NX with VB.Net.
Checking it manually: Go to the Assembly-Navigator add the Column -Weight Status- and check the green Hook or yellow "?".
The Code should read out what sign is there (green Hook or what ever).
Some lines of Code:
end if
The "UFWeight.StateType.unknown" is defined as Status 3, that means the Sign "?".
But how can i read out this Information?
Thanky a lot.
Kind regards, Frank
Here's some code I have (VB) that reads or calculates the weight of the work part. You can pass in the tag of a component to read the component weight instead of the work part.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUfSession As UFSession = UFSession.GetUFSession
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim myWeightProps As UFWeight.Properties
        Dim myWeightExceptions() As UFWeight.Exceptions
        theUfSession.Weight.AskProps(workPart.Tag, UFWeight.UnitsType.UnitsLf, myWeightProps)
        lw.WriteLine("cache state: " & myWeightProps.cache_state.ToString)
        If myWeightProps.cache_state = UFWeight.StateType.NoCache Then
            'calculate weight
            theUfSession.Weight.EstabPartProps1(workPart.Tag, 0.999, True, UFWeight.UnitsType.UnitsLf, myWeightProps, myWeightExceptions)
        End If
        lw.WriteLine("mass: " & myWeightProps.mass.ToString & " lbf")
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
