OZ970G Datasheet
OZ970G Datasheet
OZ970G Datasheet
Hey,
I am trying to repair an old lcd monitor. There is this driver OZ970G and I want to find the datasheet. Searched the internet for a couple of hours but no luck. This question was asked in the thread thread240-53517: O2Micro data sheet for OZ970G?. twodogs found it, but i don't know how to contact him now.
P.S. - I am a new member here and sorry if I am breaking any rules.
RE: OZ970G Datasheet
I can't help you with your question directly, but are you aware of the cheap ($20+) circuit boards that interface to LCD panels on one side, and the usual assortment of Monitor I/O on the other? They're most often designed for laptop LCD panels, so that they can be used as monitors. I'm not sure if they're also applicable to standalone monitors, although I suspect that the panel interfaces might sometimes be similar.
Just mentioning it in case it's applicable. Good luck.
Couldn't find the datasheet online, but I did find a schematic with the OZ970 in it. It might help you.
https://www.electronica-pt.com/esquema/lcd/oz970-i...
http://files.engineering.com/getfile.aspx?folder=3...
Oh, and twodogs hasn't logged into the website in over 14 years, so I don't think you will have much luck there.
"After joining Eng-Tips Forums on November 17, 1999, I've logged in 144 times. My last login was on Thursday, January 22, 2004. "
