reference/textbook for theory behind VIII-1 impact testing exemptions
I'm curious about the theory behind the impact testing exemptions permitted in VIII-1. Specifically:
1. Why are thin plates exempt to lower temperatures than thick plates?
2. Why is the effective thickness of plate stress in bending one-quarter of the actual thickness when determining the minimum impact exemption temperature?
Can both of the above questions be answered with classic fracture mechanics theory?
Can anyone point me to a reference textbook or white paper(s) that explains the theory behind these rules?
RE: reference/textbook for theory behind VIII-1 impact testing exemptions
On your question, toughness is not actually a material property as it can vary based on thickness. Thick components tend to have higher constraint than thinner components and are more susceptible to fracture. Corten's paper uses a 1/4 thickness flaw depth to develop the exemption curves, so the postulated flaws used in the fracture mechanics assessment are larger for thicker plates.
