FEA Free Plate Edges
Hi All,
Has anyone used Strand 7 and got the following error when trying to create a solid mesh?
"The surface mesh is not valid because free edges or edges shared by more than two plates were found"
Does anyone know what this means?
Thank-you
RE: FEA Free Plate Edges
Strongly recommend you remove this question, and re-post it in the Finite Element Analysis section. You will get more detailed attention there to this specific problem.
Yes, I got that message in the past, but I haven't done FEA (Strand 7) since 2012, so I don't remember what I did to correct it.
