A193 B7 and B-L7 bolt
Dear experts,
The drawing show A193 B7 bolt. The supplier gave me a bolt with B-L7 marking on the head.
What is the difference and which is one is better.
Syah
Syah
RE: A193 B7 and B-L7 bolt
You would likely need to confirm the dual certification, review the two specifications, your Code of Construction, if any, and assure yourself the bolting is suitable for your application.
Mike
As an engineer you should compare the actual material/chemical properties of the actual bolt and check to see if it meets your criteria instead of asking others to do your job.
