How to anchor brick shelf angles to a wood building?
I have a four story wood structure with brick veneer. The veneer height exceeds 30 feet, so we are going to support the brick veneer at each level with shelf angles. I was wondering how people typically detail the connection of the shelf angle back to wood-framed buildings.
Let's say I have maximum 12' of supported brick at 39 psf = 468 plf. The center of brick veneer will have about a 3 1/4" eccentricity from the face of the sheathing, so 468x3.25 = 1521 lb-in/ft moment. I was planning on using an L5X5X3/8 angle. What's the preferred way to attach it back to the structure? (1) row of lag screws into solid blocking between the wall studs? I'm getting that I need 3/4" lag screws at 8" o.c. to take the combined shear and withdrawal loading. I was planning on locating this angle and blocking right above the wall bottom plate, so gravity loads will be transferred through direct bearing. How do you transfer the tension of the moment couple out of the blocking into the wood studs?
RE: How to anchor brick shelf angles to a wood building?
Dik
Seems there should be a better way of dealing with 4 stories of brick.
Estimate your wood shrinkage and brick expansion and have your architect detail their window sills for this differential at the upper levels.
I believe the 30ft limit is prescriptive, but don't have the code in front of me.
Dik
I was told that the brick expands the most when it is young as it is very dry when it comes out of the kiln. There ought to be a way to let it acclimate to some degree which would minimize the expansion.
https://ascelibrary.org/doi/abs/10.1061/41016%2831...
I found this link from the Brick Industry Association that seems to be recommending supporting brick veneer in excess of 30 feet all from the foundation:
http://www.gobrick.com/Portals/25/docs/Publication...
However, I also found the following link from woodworks that to me seems to be recommending supporting the veneer at each floor level on the upper levels:
http://www.woodworks.org/wp-content/uploads/Option...
Any issue with cross-grain bending in the rimboard/LVLs when bolting the eccentric brick load to the face?
