Machinery Library Error
Hi All,
When importing a reusable machinery library part into an assembly I get the following errers (see attachements)
I've changed something in the customer properties but don't know how the setting where before my change.
Suggestions are welcome.
I'm running NX12.0.1 native on W10
Lars
Lars
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
RE: Machinery Library Error
Siemens GTAC have the following information on the issue:
The message:
"The Material Attribute was reset because it did not match the material assignment.
This action was taken based on your Customer Default setting."
should be considered seriously.
The message highlights that the Material attribute in the part file being opened have a value set which is NOT related to a material assignment to a solid body and sub-sequently there are necessarily no physical properties defined for the solid body.
The attribute defined in NX Customer Defaults Gateway --> Materials/Mass, Attributes tab, Part Material group, Attribute Title Alias field, is a NX system attribute which is reserved to be used by NX to store the material name defined when using Assign Material function.
In earlier versions there were no check or prevention to manually set this attribute. Now if a part file is opened with the "Material" attribute value set manually, the "Material" attribute WILL BE REMOVED.
If you, after consideration, found that legacy part files have manual value set to the Material attribute and it is impractical to remove or rename the Material attribute from all legacy part files. AND it is not practical to change the default part material attribute title alias there is in NX12 an option to suppress the message by setting:
UGII_SHOW_MISMATCHED_MATERIAL_ATTRIBUTES_IN_INFO_WINDOW=1
in for instance ugii_env.dat.
PLEASE NOTE: The "Material" attribute will still be removed, but now silently, only with a note in the NX syslog.
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
