Custom iProperties on multiple Part files
Dear Folks,
Stacked recently while creating Custom iProperties on multiple Part files.
Overall Length, Width and Height parameters of every part, that later will be used within IDW Part Lists.
Required units in mm with Precision of 0
Also Part surface Area in m^2 with Precision of 0.000 required.
Within Assembly BOM manager I,ve created Custom Property column, named "AREA" and scripted an evaluation to every part row "=<SurfaceArea>".
Partial success happened. All calculations appeared in mm^2, but required in m^2.
Any clues? iLogic rules? VBA?
RE: Custom iProperties on multiple Part files
Length = value
Width = value
Height = value
SurfaceArea = (calculation using length witdth height)
Did you also have to create them with unitless values?
I can't get Inventor to make a parameter with square area as a unit.
You may be able to create another parameter, this one with a different name and its calculation is "SurfaceArea / 1000000".
Then you could access that value through the iProperties and BOM custom property.
STF
I am trying avoid to open every part and set custom parameters.
Still keeping the way to create Length, Width, Height and Area parameters formatted as String from the highest level assembly to every part and subassemble that belongs to it.
Created parameters could be as follows:
Length = Calculated extension in X direction in mm,
Width = Extension in Y direction in mm,
Height = Extension in Z direction in mm,
Area = Calculated by Inventor "surfaceArea = iProperties.Area". This property could be found in iProperties...->Physical tab.
After couple hours of researching I've found myself not so familiar with Inventor API, VB and iLogic programming. But still believe that solution is somewhere here.
http://adndevblog.typepad.com/manufacturing/2013/1...
CODE -->
'current document doc = ThisDoc.Document 'unit manager of the document oUOM = doc.UnitsOfMeasure 'get the value of Area surfaceArea = iProperties.Area 'round the value with 3 valid numbers (optional) surfaceArea = Round(surfaceArea, 3) 'convert the value to a string with the unit of the document surfaceArea = surfaceArea.ToString() 'update the custom property "Area" we created iProperties.Value("Custom", "Area") = surfaceAreaAlso I'd like to change "oUOM = m^2 as UnitsOfMeasure is set to mm".
Length, Width and Height are left to find iLogic script.
