MS threaded joint
MS threaded joint
Dear sir,
To joint the threaded MS pipe, sealant is better or Teflon tape application is good?
Available market sealant are holdtite of pedilite, etc.
Pipe application is of water line and air line
Pls suggest.
Prasad Rode
Pls suggest.
Prasad Rode
RE: MS threaded joint
AsSumInG it is some form of tapered pipe thread, my preference is thick teflon tape for convenience and lack of mess. However, If there are components down stream that could be affected when shards and threads of teflon come adrift, some form of sealant is likely going to be "better."
Applying tape with an unusually high level of craftsmanship can reduce the risk of tape shred to near zero.
MS16142C, MILITARY STANDARD: BOSS, GASKET SEAL STRAIGHT THREAD TUBE FITTING
