100 psf live load at second floor lobby
Asce 7-05 and IBC both call out for a live load of 100 psf at lobbies and first floor corridors. Is the lobby being referred to here for all floors? I generally design all upper floors of office buildings for a live load of 80 psf. You could have a large lobby area around an elevator shaft, should I design this area for 100 psf (may or may not know the lobby size if it is a shell space)? Another unknown on shell space is assembly areas. Say the owner puts in a large conference room, would you consider that an assembly loading and require the 100 psf loading. What size area would warrant assembly loading in an office building?
RE: 100 psf live load at second floor lobby
Dik
Dik
Agreed. You run the numbers on some of these live loads and it's like a bunch of heavy folks packed in there like sardines.....but I try not to take any chances.
I found the following passage interesting. It is taken from an article written by Richard S. Fling, former president of ACI:
