Instance Name & number from selected part
I'm trying to get the instance name from a selected part but with no luck.
I cant find anything in the v5 automation file but found some code online.
I have asked this in another thread but I thought I would ask everyone as i'm stuck.
Set InstName = CATIA.ActiveDocument.Selection.Name.Value "dosent work"
Set InstName = sSel.Item(1).Value "This one returns the part name"
thanks
Alan
thanks
Alan
RE: Instance Name & number from selected part
If you are in an assembly and you've selected a product from the tree, you'd have to use this:
CODE -->
You'd also need to learn basic VBA concept before attempting to script in CATIA (e.g. use 'set' to assign object to variables, not strings).
Calin
Thanks for the reply but the code would show the part name not the instance name & number.
Do you know how to modify it to do so?
regards
Alan
I am very sure that IF you are in an assembly (CATProduct), your active document is the CATProduct and you select an item from the tree, the code I provided would return the Instance Name not the Part Number.
Please see the attached image for details.
Calin
Your quite right.
Alan
