Column web bending under axial loads
How to check column web bending under axial loads (tension and compression)? Is there a paper which talks about this? Like yield line theory?
RE: Column web bending under axial loads
Also, equation 9-29 (which is more of a punching shear equation) is also something you'll want to look at.
