Why is the MMC modifier used so much more often than the LMC modifier?
I work for an aerospace company that seems to add the MMC modifier to almost every tolerance and datum reference possible, but I never see the LMC modifier used. Is there a reason the LMC modifier is used less often? Is it related to the inspection requirements for the part?
I understand that inspecting a feature toleranced with an MMC modifier can be inspected easily with a go/no-go gage, and I guess that would not be applicable to the LMC modifier, but does it make a difference if the part is being inspected by a CMM?
Along the same lines, does it make sense to use the MMC modifier on tolerances for features that are not part of the interface with another part vs. just using a larger tolerance?
Any help is appreciated.
RE: Why is the MMC modifier used so much more often than the LMC modifier?
LMC is usually applied when sturctural concerns are driving the design. Like: the wall thickness of thin-wall tubing is at its worst when ID and OD are at LMC size. Tube sheets in heat exchanges are another example - the materal ligament between tube-holes is the smallest when the hoels are at biggest size - LMC.
Think through the problem you are trying to solve. If you are putting a screw or bolt through a hole that is oversize, you can open up tolerances a bit. You specify MMC/B. Don't just mindless apply tolerances. Solve a problem. I have used LMC/B twice.
The first time was a casting with two accurately bored holes in it. I had to ensure that the as-cast holes provided material to be bored out.
The second time I did it, I was ensuring there was adequate material thickness between two holes. I don't run into this problem very much.
JHG
I find that I actually frequently encounter cases where I think LMC is the best way to go, so what I want to know is if there is some reason why it is not being used.
I have a hypothetical question: if you have a 1 +/- .010 hole which cannot violate a 1.040 diameter boundary. Would there be any benefit to using a position tolerance of .010 with an MMC modifier vs. just a .030 position tolerance RFS?
I see situations like this a lot and the only rationale I can imagine is something related to the inspection process.
One benefit of the first option is that it actually achieves your goal, while the second option only prevents the hole from violating a boundary of diameter 1.060 centered at true position. Keep in mind that the hole doesn't have to be perfectly cylindrical.
LMC position tolerances can indeed be used to ensure sufficient material exists for a subsequent machining operation, but I think profile tolerances often make more sense in these cases. If you can tolerate a certain amount of extra material on one side of a hole, you can probably tolerate that same amount all around.
LMC position tolerances can also be used to ensure adequate material thickness between between features, but I think directly tolerancing the minimum wall thickness often makes more sense in these cases. Providing fixed boundaries that must not be violated is probably more restrictive than necessary.
I don't mean to imply that LMC position tolerances never make sense, but I do think some of the more commonly discussed applications are rather questionable.
pylfrm
MMC modifier is beneficial (bonus tolerance and everything) in almost any situation of two parts fitting together, including fasteners to hold them.
And since nearly every machine consists of parts assembled with the fasteners, you see MMC modifier everywhere.
Also, conditions of mating parts (like Virtual Condition) have simple practical meaning - they give you sizes for your functional gauge(s).
LMC on the other hand is trickier. The LMC virtual condition is buried inside the material. it cannot be measured or checked with the gauge.
You need complicated techniques like CMM or scanning to establish where your boundaries should be located and how far away your part is from those boundaries. (Or you can check wall thickness with the caliper
Sidebar: My spell checker quite working. Anyone know how to get it going?
You have an assembly where a pin needs to fit into a hole. You know that both size and location need to be controlled -- and for now let's just think about designing the hole.
Option 1) As the hole's size gets bigger, we can let its position scoot around a little more
Option 2) As the hole's size gets smaller, we can let its position scoot around a little more
Which of those two options seems to make sense in order to allow for the mating pin?
(BTW, Option 1 is what MMC does, and Option 2 is what LMC does.)
Here is the problem most of us solve most of the time...
The bigger the hole is, the more positional error can be tolerated. MMC/B provides a bonus here.
JHG
See the examples above by other posters, where LMC controls are used on feature created mostly by additive methods (casting, etc).
As usual, this is a generality, and all of the detailed analysis of GD&T in the above posts is equally applicable to the question.
That machining callout probably uses an MMC modifier, because in that step material is being removed.
H. Bruce Jackson
ElectroMechanical Product Development
UMD 1984
UCF 1993
The above statement is not true if LMC and RFS modifiers are used interchangeably in simple cases as described (min/max distances/wall thickness between the features is NOT the same if LMC modifier is used versus RFS). Likewise, the results are NOT the same if LMC and MMC modifiers are intermixed or swapped with one another.
That could be, one of the multiple reasons, on why MMC is more “popular” than LMC: stackups
