NX11 - Pallettes Code in .pax file
I have a pax file with about 65 components in it. Is it possible to manipulate the code in the pax file to collapse groups of components so that in the pallet navigator they can just expand the "Washers" and select the one they want? Or would this be worthless because if we wanted we could place them on different pallettes?
I was considering creating several different pallettes but then this would force every operator to load several pallettes up. If I could make them collapsible, it would allow them to load only one pallet up and have them all available.
RE: NX11 - Pallettes Code in .pax file
HI,
Have you looked at Reuse Library instead?
There its possible to create folder structures and you don't have to mess whit pax-files.
Mattias
NX5 -> NX12
I-deas 12, NX I-deas6.6
Solid Works 2017
