Support plate (baffle) - floating tube sheet heat exchangers
Hi!
Could anyone explain me, why the support plate (the baffle next to the floating tube sheet) in floating head heat exchangers (for example BES TEMA type) has usually cut out piece of material? Not like standard segmental baffle, just for example small square inside the diameter of the support plate. Is it necessary? Why can not it be done as a full diameter plate (baffle)?
Best regards!
Dawid
Best regards!
Dawid
RE: Support plate (baffle) - floating tube sheet heat exchangers
Mike
So the only result of the construction without window in the support plate will be reduction of the heat exchange area equal to the outer surface of all tubes between the support plate and the tubesheet, right?
Dawid
Dawid
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
I would like to go one step further: I have found a few information that the window in the support plate is mandatory for floating head but not necessary for U-tubes. I have found a few drawings as well where the U-tube budnle has solid support plate. What is the difference between these two solutions, excluding issue which EdStainless described (preventing of floating). In my opinion fouling and UDC probability is the same for U-tube and floating head.
What do you think about it?
Taking this back to the basics, can anyone shine a light on the benefit of such a baffle? Why is it there in the first place? Why not just shorten the tubes a little and locate the tubesheet where the last baffle would have been?
The floating head support plate is generally used in an exchanger with a removable shell cover, and its job is to support the floating end of the bundle when the shell cover is removed. The floating head must extend from the shell so the bolting is accessible. A floating head exchanger may also not have a removable shell cover, and in this case the floating head support plate is generally omitted.
The support plate in a U-tube exchanger is there to support the tubes, all of them. It is generally used when the shell inlet / outlet nozzle is located ahead of the U-bend tangent. In this arrangement the U-bends are often considered ineffective in the ratings calculations. When the I/O nozzle is located beyond the bends, another type of U-bend support is often used either a strip type support or a drilled plated fitted to the U-bends themselves.
Now, back to Mandalore's last post, I feel the same considerations with stagnant areas apply as well, and it is generally my practice to cut the U-bend support top & bottom, outside the tubefield of course.
Mike
An afterthought: An floating head exchanger must be a T-Type, not an S-Type to use a non-removable cover, the entire floating head must fit thru the shell. Packed floating heads are a different animal altogether.
Thanks very much, I hadn't considered the aspect of supporting the the tubesheet when the shell is opened. Learn something new everyday!
Cheers,
Marty
Also help to extract and insert the tube bundle in the shell.
r6155
