Cut using an arc in drafting
Hello boys,
can someone help me how to make a cut using an arc in drafting? Please see the drawing in the attachment. I have NX11, Win 7. Many thanks
RE: Cut using an arc in drafting
What you want is not possible.
If you have seen this before then it was not done correctly.
Jerry J.
UGV5-NX11
Use this command, sketch an arc, use this arc to cut your model. Another thing make sure you have your model views setup correctly when making your section. Now you can process this view to your 2D drawing. This is a quick mention of commands. If you want I can make an video.
Also your lines and arcs are splines, it will be very difficult to measure to. We usually have to sketch lines on top of our geometry to get what we want.
Edit
I attached a quick example. It is not perfect, but we need to do this every so often. Especially for Helical Described features. We have to sketch in our Section lines.
