Dual rated CT
Dual rated CT
Dear friends
Does anybody knows about dual rated CT's
Is it single core suitable for metering and protection?
Or two core CT (1 metering and 1 protection) is called as dual rated CT
RE: Dual rated CT
A "two-core" is referred to as a dual-core CT which is two separate cores contained in one housing.
RE: Dual rated CT
For example, a 5P CT is supposed to meet Class-1 accuracy requirement in the load current range.
The problem arises when the client stipulates Instrument Security Factor (Fs) for metering requirement. Protection class CT will not meet this requirement.
Rompicherla Raghunath
