can any one advise me the method to
can any one advise me the method to make design calculation for a blind flange with NPT port ?
RE: can any one advise me the method to
prasenjith, it would help a lot if you would state your Code of Construction, if any. Piping? Vessel? US Code? Foreign Code? Custom blind? B16.5 blind?
ASME B16.5 permits blind flanges to have a centrally located tapped hole up to certain sizes, I believe. Otherwise you are likely falling under the Code of construction.
Mike
i think u should go for ug-39 in asme bpvc sec viii div.1 if u r using this code of design and construction
SnTman
It’s Api 6a blind flange with npt port in the centre
Taba94
