Depth of Cover calculation
Hi, I have a question about the pipeline depth of cover calculation. CSA Z662 list the minimum depth of cover requirement in Table 4.9. We are now considering the effect of frost due to the cold weather on the pipeline underground, such as water service line. The report in this link below is used for estimating the frost depth. However, there is any experience and calculator you can share about this topic? Thanks.
https://dm.huskyenergy.com/OTCS/llisapi.dll?func=l... less
RE: Depth of Cover calculation
It may be an issue of what is flowing and the temperature, the rate of flow, and the consequences of the fluid freezing.
Dik
