Curve fitting an elephant
RE: Curve fitting an elephant
Hmm. I get the elephant part in my usual bumbling way, using MS-Excel...but he's rotated 90 degrees, which puts his eye in the wrong spot. It's probably because I'm in the upper left quadrant (NA) vs. Greg who's in the lower left (Oz). Also not following the wiggle parameter, so mine just stares at you fixedly, like that guy at the end of the bar near closing time.
Animated GIF or get out
Both mine and Greg's ARE animated, given that they both contain the x(t) and Y(t) time based parameters. I.e., these are 4-dimensional depictions of the quantuum states of the elephant...to see them move requires that you imbibe at least 3 cans of Foster's Lager (in Greg's case) or the equivalent number of pints of Old Schoolhouse Ruud Awakening (for mine). And tomorrow they will be pink, and chase you around the toilet.
Only tourists drink Fosters.
I cheated, I actually plotted (y,-x). I'd point out that they haven't really used 4 variables, because you need 5 complex numbers it just so happens that the 4th is zero. That is, there is more information than just 4 complex numbers in the coding.
Here's a slightly better bit of trunk wiggling and the thinner lines show how the ellipses add up
Cheers
Greg Locock
He in OZ. True, it's in the other quadrant, but he's looking at the back of the screen too.
But it all works out: His AC current runs on a cosine curve, going backwards half the time.
I just realised these are Lissajous figures. So someone with a real oscilloscope and a talent for harmonic oscillator design could build a circuit that traces the elephant out. Now that is a science fair project!
Cheers
Greg Locock
How about a hippopotamus generated by a potentiometric X-Y plot?
Quote (danw2)
How about a hippopotamus...
Looks more like a rhinoceros to my untrained eye... glasses
I agree with cowski!
Very neat, Greg.
Now come up with a 4-bar linkage that will draw it!
STF
Getting that imaginary link to fit properly is the real trick winky smile
Here is my CNC programming project from college. I still have the punched tape!
JHG
We scanned a cow with our LIDAR system back in the 90s for a college professor. Unfortunately I don't have an image to show.
Z
Okay, reminds me of a joke.
A guy goes to the psychiatrist.
The psychiatrists shows him a card with a rectangle on it, and says, "What does this remind you of?"
The patient responds, "Sex!"
Next, the psychiatrist shows him a card with a circle on it and says "How about this one?"
The patient again responds, "Sex!"
Next, the psychiatrist shows him a card with a triangle on it and says, "And this one?"
"Sex!" is the answer again.
The psychiatrist says, "I think I see your problem. You seem to be obsessed with sex."
"I'm obsessed with sex?", the patient says, "Look who's showing the dirty pictures!"
So let's just say that elephant could use a couple more constants to really look like an elephant instead of an amoeba.
The 4-bar linkage does sound like a worthy challenge, though.
Hmmmm... looks ready for FEM... Finite Elephant Analysis...
Regards, Wil Taylor
o Trust - But Verify!
Years back, I went to the local jewelry/lapidary supply place, found some tiny stone elephants, attached them to earring mounts to make "earelephants".
