special building vs intermediate building
hi everybody
I'm designing a building where the beams in the secundary direction fail by lb/ry>0.17 E/fy i cannot undertand why a secondary member required a section higher than the principal.
you can see the image i'm using etabs, and intermediate design for a building with 7 story
if i use LRFD93 to desing the members are good but using aisc 360-10 are bad, but is ilogical
please somebody that use aisc 360-10 with etabs talk about this results
thanks in advance
cris.
RE: special building vs intermediate building
The results to LRFD 93 and 360-10 appear almost identical. Why do you say one 'is good' and the other 'is bad'? Am I missing something...?
the beam are red in AISC 360-10 results because lb/ry>0.17 E/fy not by the ratio red mind failure in this software
