Anti-sag Rod Design for either Roof or Wall Purlins
Does any one could tell me the difference between these two rod arranging patterns in the following picture? When should the first pattern be used and when should the second pattern be used?
Many thanks in advance.
RE: Anti-sag Rod Design for either Roof or Wall Purlins
Isn't the failure mode you referenced up the slope not down the slope? Well, depending on the slope of the roof. This is the failure mode I have seen with roof purlins in the past. The attached photo (which isn't great) is of a roof purlin that has begun to fail by rolling over towards the ridge.
The lower sketch would be best if the net anchorage force is pushing the purlin top flange uphill. This would normally be the case on a lower pitch roof.
Net anchorage force is going to be the directional sum of the rotational forces due to the purlin shape,which will generally push the cross-section towards the upper flange (function of the forces and the angle of the principal axis of the section), and the gravity component of the force which is always going to push the purlin downslope. For a 0 slope roof, rotational force is at a maximum and gravity force is zero. For a steeper pitch roof, the rotational force is smaller, and the gravity force is larger. Rotating the purlin to have the top flange facing the other way is not recommended for anything but minimal slope roofs, but will then make the two components additive and both would be oriented downslope.
Yes, I have read some similar points like yours. Actually this picture was taken from a cold roll-reforming company's catalog. In this catalog, it is said that the zed purlin tries to roll backwards when the roof slope is bigger than 10°, while in other cases it tries to roll forward. I couldn't understand how did he get this conclusion because only the first arrangement is konwn to me in practice.
Also, the most popular point I have read is that when the first arrangement is used, the anti-sag rod would prevent the zed purlin from torsion under wind suction. But how about for the second arrangement? Can it work as lateral support in the same way?
Are sag rods commonly used? Not in Australia, we always use purposely designed bridging which braces both top and bottom.
I work for BlueScope (Butler and VP brands) and we utilize a 5" deep channel to cover both flange requirements.
As noted for slopes under around 1.5-2:12 the rotational forces are larger than the gravity force component and the purlins will roll uphill.
BlueScope, as you would know, is an Australian company. For purlins and girts, they use the old Lysaght brand here. Have you adopted the Hook-Lok bridging system?
http://professionals.lysaght.com/sites/default/fil...
