Strength of brazed copper tube
Are there any ways to estimate tube/pipe material strength after brazing operation?
The application I am looking may require a section of thick walled H80 copper tubing, and the joins to a brass block by brazing.
I am aware that brazing basically anneals the material, causing it to have lower strength overall. Would it be safe to use the numbers (to calculate wall thickness) for an annealed temper, e.g. OS050?
Any insights or pointers for further research is welcome.
RE: Strength of brazed copper tube
