Create model in Excel for automation
All,
I would like to know how to build a FEA model in Excel and import it into FEMAP. This is more like automation so that non-FEA person can simply change the material properties or change the thickness, to do some parametric studies.
Is there any process that you would like to share?
Modeldamper
Modeldamper
RE: Create model in Excel for automation
Also, if it is requried to retrieve the result output from FEMAP and carry out further calculation process, running a macro from EXCEL is a good choice.
This can be done with the Femap userinterface with commands like Model > Output Process, Model > Output Calculate, etc.
This can also be done within the native API when these commands are used frequently in the same way.
