Testing; Choosing the right sensor for RPM
I have no previous experience collecting RPM data so would like advice from those with previous experience. I need to collect RPM data from my machine and record it's behavior as I apply and remove power. I'll be engaging and disengaging a load. So I'm trying to find out how long it takes for it to come to a rest when I remove power. There are a few pulleys and spindles I could have a sensor observe to collect the data from.
My question, what is the optimal sensor for this job? I've come across information to suggest a hall effect sensor or an optical lazer sensor could fit the bill. There will be a fair amount of vibration so I'm not sure if that creates a big disadvantage for either sensor.
-Max RPM is under 4,000
-time for the output to come to a rest should be about 2~10 seconds.
-sample rate only needs to be about 100 Hz. (would like to reliably know within at least 0.1 s of output stopping)
Anyone familiar with this type of test have some recommendations??
RE: Testing; Choosing the right sensor for RPM
It might be important to know:
What is the expected max speed?
How long do you expect it will take to "come to a rest"? Minutes? Seconds? Micro-seconds?
How accurate do you need to be for the overall time?
How accurately do you need to know what happens while it is coming to rest?
Many of those question also affect the choice of data logger.
@MintJulep - Thanks, I added the information to the OP
Only thing I have used is an encoder on a shaft. I designed a control system for a small prototype turbine spin up test. It worked really well. The turbine was connected to a air motor and all of it was bolted to a steel test bench.
Your collection rate seems to be in conflict with your stated speed --> 4000 rpm = 66.6 Hz, so 100 Hz sampling will potentially given you weird results at speed, unless you don't care. I would think 400 Hz might give you better data for steady state.
I assume your vibration is not specifically the shaft against its mount.
There are lots of possibilities:
> Hall effect
> Absolute encoder
> Back EMF measurement at motor windings
> gyro
TTFN (ta ta for now)
And you'll need some way to indicate when to start timing.
@IRstuff, max RPM will be less than 4,000. It will always be between 3,000 and 4,000 for max (usually somewhere near the middle).
For the vibration, my first test is gonna be a lawn mower, so the whole chassis of the mower deck should be vibrating a fair amount, but I'm not sure how much movement there will be from the shaft relative to the deck.
@MintJulep, When I remove the power it should be the start of the timer, since it will need power to remain engaged.
Nevertheless, 3000 rpm = 50 Hz, so 100 Hz is barely two samples per cycle, which will make it difficult to see what's going on at the start of the spin down and the end of the spin up.
The shaft had better not be translating relative to its bearings, otherwise, you have bigger problems than starting and stopping times.
For engines with self-starters, the industrial standard seems to be a magnetostrictive sensor affixed with its tip close to the starter ring gear teeth. There are a large number and variety of transducers to convert that N pulses/rpm signal into whatever else you might like. The typical number N of say 70-200 can give decent resolution of rotational speed, even within a single resolution, but it's not the sort of thing you can do directly with an Arduino or similar.
Well, maybe you can; I haven't worked with an Arduino, so maybe they are fast enough, but time-based sampling, as noted, is not going to give you what I think you want. You need something that produces a fair number of pulses per revolution, and measures the time between successive pulses, then computes RPM from the pulse rate.
Mike Halloran
Pembroke Pines, FL, USA
Almost every engine with electronic controls has a crank position sensor and / or a cam position sensor. The sensor is usually some form of magnetic field sensor, can be variable reluctance, hall effect, etc. (I'm not aware of anyone using an optical sensor these days but it could be done. I think they are overly sensitive to dirt in many environments.) These are generally reading a toothed wheel with 60+ poles. Usually one pole is missing so you can determine where you are in a revolution. Automotive wheel speed sensors for ABS and traction control are the same but generally don't have a missing pole. There are 10's of millions of these made every year, they are cheap & reliable. They will withstand heat/cold/vibration/shock.
@MikeHalloran & @dgallup, in order for that to work, I would need a gear tooth that I attach to the shaft, correct? (currently there is none)
Yes, you need something that looks vaguely like a gear, preferably made of steel.
I'll possibly save you some time here; plastic gears exist, of course.
If you wish to use one with an optical sensor, face it with metal foil or brass.
Even 'black' plastics are translucent at the infrared wavelengths used by optical sensors.
Worst case; you start with a low-gain sensor that can't see through plastic, and
later you get a batch of sensors with higher gain, same part number, and
they can see through your gear or interrupter flag or whatever, and
you get to retrofit truly opaque parts because you can't get a sensor
that's reliably bad enough to work. Happened to me a long time ago..
Mike Halloran
Without knowing the exact motor there is no useful suggestion. What's the reason for caring how long it takes to stop?
Optical sensors can be a bit easier to package. You can get dead posh ones that don't need stripes but the ones that pick up off reflective tape are good and robust. Beware of resonances in the mounting bracket for the probe.
Cheers
Greg Locock
If you only need short term durability I would lean toward an optical sensor with a reflective tape or other marking, its cheap and easy to install. If you need durability then I would recommend any of the various timing wheel schemes mentioned above using hall-effect or other sensors.
@3DDave, sorry if my OP wasn't clear.. Engine is not a factor, since I will be only looking at the output load. I'll be engaging and disengaging that load from the engine, but I'm only concerned with the time it takes the load to come to a full stop when I remove power from it.
@GregLocock, dead posh? I'm not familiar, could describe?
@CWB1, Since I'm trying to be cost effective, that sounds in-line with my preferred approach. I'll probably utilize this on multiple machines, so if it is easier to setup, that will be a bonus too. Do their tend to be calibration issues with the reflective tape option?
If an item is not a factor, don't add it as a factor in your problem description.
@3DDave, I didn't. But if I'm somehow missing where I added it as a factor, please feel free to highlight it for me so I can correct that.
You are correct - I extrapolated from "lawn mower" to include a motor. So, substitute "lawn mower" for "motor" in the objection because "lawn mower" adds no clarifying information. It could be a push mower or a 50 foot wide tractor pulled gang mower.
There is still an infinitely large solution space. One could use a tachogenerator or a magnetoinductance tachometer or just two pickup wires that are shorted by a paperclip taped to something that moves attached to a timer or a centrifugal switch via slip ring or ................
What still impresses me is that your stated goal is measuring coast down time, which is a matter of losing kinetic energy stored in the machine (can be calculated) to various friction losses (some can be measured, others estimated) eliminating the need for testing.
Alternatively, the whole thing can be estimated by running the machine at various RPMs and measuring the power required to drive it at those speeds and then integrating to get an energy-loss curve. The area under the curve to any point represents the kinetic energy that will be absorbed when the power is cut off. This can be integrated over RPM to create a direct reading chart. Since the mechanical energy storage can be calculated for any RPM it's just a matter of looking at the chart.
Or you could just use a camera and record a video. Depending on the camera you can easily get the time to within 1/50th or 1/60th of a second or less. Or a sound recorder and run the result through Audacity or something similar.
I think based on everything I've looked through and feedback received. CWB1's suggestion is the one I will be moving forward with. Does anyone have a suggestion for optical sensors or brands they have found to be reliable?
I have used several of the Monarch Instruments sensors as indicated by Tmoose above. You have three choices for optical sensor: visible light beam (most common), laser beam (gaining popularity) and infrared beam (IR has advantages depending on application). The laser and IR sensors can possibly detect passing shaft key or keyway, so reflective tape may not be needed. Contrasting light-dark paint may also give a signal without needing reflective tape. You cannot measure down to Zero speed with most 1-pulse per revolution sensors. We would need much more details about your application to be of help.
Walt
@Strong, sorry details are a little limited, it is a test I will be doing in the future, so unfortunately I don't yet have the test materials/equipment on hand.. I figured the concept is simple enough and common enough to get started on it now, before I get the equipment. Once the machine is on hand I wont have time to wait for shipping and such, so need to prep ahead of time.
"I figured the concept is simple enough and common enough to get started on it now, before I get the equipment."
This is a good idea. Having measured many machine startups and coast-downs, I can say that transient measurememnts of speed, vibrations, sound, ultrasound, motor current, torque, and torsional vibrations presents greater challenges than steady-state measurements.
Walt
Walt Strong may have some examples of the practical resolution limitations on a rapid coast down and a 0nce-per-rev tach signal.
Monarch could probably give you some idea as well. I would trust them to shoot straight.
OP: "So I'm trying to find out how long it takes for it to come to a rest when I remove power."
If you truly need to detect when Zero speed (at rest) occurs, then you should look at encoders and not 1xSS sensors, of any type. There are some hollow shaft encoders, but most mount on the end of a shaft. If you can do your test down to some defined "minimum speed", for example 5-rpm, then you could probably use a 1xSS or multi-pulse tachometer. I suggest additional study on what you want/need and what can be done with various speed measurement methods and sensors. Consider getting a free demonstration or renting before purchasing stuff that does not work to your expectations.
Walt
