MAWP vs DP for calculating minimum required thickness
Hello everyone,
What pressure value (Design Pressure or Maximum Allowable Working Pressure) should be used to calculate vessel's post construction minimum required thickness (Tmin)?
If proving an example helps the understanding of the question, let's say that after reviewing the vessel documentation I was able to find DP=250 psi and MAWP=275 psi. The vessel has been in service for several years and it has general loss of thickness due to corrosion in the shell at a well known rate. I want to calculate the remaining life of the corroded area of the shell, and therefore I need the Tmin as an input for the remaining life calculation.
I'd go ahead and use UG-27 formula to calculate Tmin, but what pressure value should I use? DP or MAWP?
Thanks!
Thanks!
RE: MAWP vs DP for calculating minimum required thickness
r6155
If you were to accept a thickness based on the design pressure, then you can no longer safely operate the vessel up to the MAWP, and you're creating a dangerous situation for anyone that isn't aware of your approach.
If you perform calculations based on the design pressure and your future inspections are based on this, then the vessel should undergo a formal re-rating to lower the MAWP to equal the design pressure. This would be deemed an alteration, would require the attachment of an alteration nameplate, and would be documented on an R-1 form (assuming NBIC jurisdiction).
r6155 Thank you for your reply, however I do not get your point. Can you please clarify? What exactly do you mean?
Calculate P in UG-27 using actual thickness (corroded), S, E and R (corrosion =0)
If P is greater than DP= 250 psi (your example) then nothing you need to do: continue in service until next inspection.
If P is < than DP= 250 psi you need to re-rate this pressure vessel.
r6155
r6155
