datum call out on section view
Scenario
Question:
What is the proper way to identify this datum on other views?
do we:
A) just attached it to one side of the diameter
B) create a reference version of the diameter dimension and attach it to this one just like the original/official one
C) I'm pretty sure it should not be attached to the centerline
D) none of the above
E) ???
- round part with multiple diameters
- one of the diameters is a datum
- this diameter dimension has the datum flag attached to the extension line, directly in line with the dimension line
Question:
do we:
E) ???
RE: datum call out on section view
3.3.2 /ASME Y14.5-2009
Where the same datum feature symbol is repeated to identify the same feature in other locations of a drawing, it need not be identified as reference.
If your CAD system allows it, create "empty" dimension without numerical value.
If in the other view cylinder appears circular, you may create leader and attach flag to it.
No, centerline is no use.
So it sounds like I need to create a reference dimension in each view (or as CH suggested a blank dimension)to attach the datum flag to. And yes I am aware of the leader on views that the datum shows as round. But if I have a side view, a projected side view (because of some features that are not round), and a section along the axis side view; that I will need to create two reference/blank versions of the dimension for these other tow views
Your datum must be attached to a feature. Attaching it to a diameter specification accomplishes this. In a view without the diameter, attaching it to the feature means the same thing.
JHG
