AWS D1.1 OFFSORE WPS QUALIFICATION REQUIREMENT
Dear
We have below material for structural fabrication as per AWS D1.1 on offshore kindly suggest me which is best, minimum test coupons cover maximum for SMAW welding process .
1) pipe - 0.625''od x 0.625'' thickness material API-5L Gr.X52
2) pipe - 1.9'' od x 0.365'' thickness material API 5L Gr.B
3) PLATE- SA36 ,25mm thickness
4) plate API 2H, Gr.50 ,30mm thickness.
5)PLATE -EN10025 S355-JR ,5mm thickness and 25mm thickness
and what are the testing requirement.
