Display Attributes?
Display Attributes?
Display Attributes?
My boss asked if it is possible to display the attributes of holes on the screen in modeling. For instance in modeling, to turn on a setting or something and all of the holes will display their attributes. M8, DIA 8 H6, DIA 10, etc.... or ,maybe even just their diameters.
To my knowledge there is no setting to do this, but I figured I would ask. Never know when I might be surprised.
RE: Display Attributes?
You have tried Right click the feature in the graphics- Show Dimension ?
Tomas
hanks Tomas. I will admit, I didnt know you could do that. lol I will show him that in the morning. Though I asked for even the diameters, I never talked to him if that would be enough and I dont expect it to satisfy him, but maybe it will. Might be he will see it as a better than nothing kind of thing. lol
After showing dimensions do a right clic on one dimension and select show as PMI.
If not the dimension doesn't after refresh F5.
Didier Psaltopoulos
http://www.psi-cad.fr
I have a journal that looks for hole features in the model, renames one of the hole edges, and turns on object name display. After running the journal, all the holes are labeled in the graphics window. Something similar could be done with the hole size info. Note that the names would not be associative and if/when the hole size changes the journal would need to be re-run to update the display. Combining the journal with some menuscript might make for a fully automated solution...
www.nxjournaling.com
cowski, would I be able to get that from you? It might be worth a shot and possibly too late now as I think my boss went a different direction, but I would still like to see it and learn from it myself. See if I can make it work for the future when I get time.
The code is below. It is really just some concept code that I was tinkering with a long time ago (i.e. it doesn't do any error checking and isn't useful by itself). When run it will look for hole features in the work part and rename all the edges of each hole feature "hole 1", "hole 2",... "hole n"; then it turns on name display in the work view. When you rotate the model around, each hole feature is labeled. It could be modified to pull attribute or expression info from the hole feature rather than applying a generic name. Here it is FWIW:
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        'Dim lw As ListingWindow = theSession.ListingWindow
        'lw.Open()
        Const holeNamePrefix As String = "hole"
        Dim counter As Integer = 1
        For Each tempFeat As Features.Feature In workPart.Features
            If TypeOf (tempFeat) Is Features.HolePackage Then
                'lw.WriteLine("name: " & tempFeat.Name)
                'lw.WriteLine("timestamp: " & tempFeat.Timestamp)
                Dim theHole As Features.HolePackage = tempFeat
                'lw.WriteLine("num edges: " & theHole.GetEdges.Length.ToString)
                For Each tempEdge As Edge In theHole.GetEdges
                    tempEdge.SetName(holeNamePrefix & counter.ToString)
                Next
                counter += 1
            End If
            'lw.WriteLine("")
        Next
        'lw.Close()
        'turn on object names in the work view
        workPart.Preferences.NamesBorderVisualization.ObjectNameDisplay = Preferences.PartVisualizationNamesBorders.NameDisplay.WorkView
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Thanks cowski
Im looking forward to a chance to delve into it some. :)
