Aircraft on ground simulation - Simulink
Hi there,
Could anyone help me with my Simulink model? I am trying to simulate an aircraft (A320) going around the airport on its taxi route. Iv used some dynamics equations (source attached) to mathematically represent the motion of the plane. My aim is to keep the velocity at 10m/s and for now.. zero steering angle on the nose wheel. However it is not working as I would expect it too
Later on I would like to design controllers which can allow the model to follow a pre-defined path by controlling the steering angle. But For now, I would just like to get this model working.
Everything is attached in the email. Please run the matlab script before the simulink model.
Any help appreciated.
Lloyd
Edit - if this is the wrong thread please let me know
Lloyd
RE: Aircraft on ground simulation - Simulink
To get help from more members, it is usually best to describe your problem in enough detail that people without the exact software can help you.
If you think it's just a coding issue, then there is a forum for that: http://www.eng-tips.com/threadminder.cfm?pid=576
STF
