Sensor
Sensor
Hi all,
Do anyone knows what type of sensor is available in the market to detect the size of the object. Like it area etc. How can i detect a object size.
Thanks in advance.
Thanks in advance.
RE: Sensor
TTFN (ta ta for now)
RE: Sensor
I’m trying to detect DC power supply adapter sizes. So probably 4cm by 9cm and smaller.
RE: Sensor
what are you going to do with the data that you collect
RE: Sensor
RE: Sensor
The normal method for that would be weight. Use a conveyor weigher. Select some number of the type-one chargers and weigh them. Then do the same for the second style. Use the average for each with a tolerance. They'll definitely weigh different amounts. You may be able to weigh them without a conveyor and have the same hand shove them into the appropriate box after the unit beeps. It can be under a second.
Keith Cress
RE: Sensor
Dan - Owner
http://www.Hi-TecDesigns.com
RE: Sensor
RE: Sensor
-AK2DM
"It's the questions that drive us"
RE: Sensor
If this is related to recycling and resale, then beware that many adapters can be packaged identically but have variable electrical characteristics.
RE: Sensor
RE: Sensor
RE: Sensor
RE: Sensor
Walt
RE: Sensor
Steven Ksi
https://panasonic-plc.com/cj1w-id211/
