what is the purpose of restriction orifice multi holes in fly ash air pneumatic conveying systems
from this link one of the purposes is reduced a noise Link,
but what kind of noise? why its needed for inlet air conveying of fly ash from economizer hopper,
Thanks.
Thanks.
RE: what is the purpose of restriction orifice multi holes in fly ash air pneumatic conveying systems
however my guess is that you have a high pressure air supply? which is needed to reduce in pressure?
If you have only one orifice plate with a small hole the air will or is at sonic velocity. That makes a LOT of noise at a high frequency.
Putting a number of plates in series means each one can operate at a velocity at the orifice of less than sonic hence lower noise.
If this is actually for the air with fly ash in it then I can only imagine that they want to keep the velocity down to reduce erosion.
give us a bit more to work on and we might have a different response...
Also depends on the area ratio of orifice to duct as the sonic jet might take a little time to slow down.
Can you give us any more background to this?
Is the question: Why are multiple nozzles used in some ejector pump designs rather than a single nozzle?
