Define element properties
Hi everyone
I would like to ask if you can please help me, when i define the material element property when i select all the elements, the property set name automatically disappears.
if i select the the application regioan and then click on the solid then the element property sets to the material but then i start to export the .bdf file then the error comes that" some elements in the model have no property defined"
kindly help me out in defining the element properties and to export the element properties file for msc marc.
