What is balloon form or balloon frame - ligth steel gauge structure building
When building houses and structures using cold formed steel gauge sections ("C" sections),
what exactly does one mean when referring to balloon form or balloon frame?
I am a welding engineer, recently called to assess certain nodes at wideflange columns in a light gauge steel building, and have picked up this name.
I don't know what it means, and the situation didn't allow to ask for much apart for what the subject of the day was.
Google acknowledges the name, but I didn't find a site where they talked about this specific topic.
Anybody care to enlighten me (or point me to a good online explanation)?
Thx!
Thx!
RE: What is balloon form or balloon frame - ligth steel gauge structure building
This is in contrast with traditional framing where the studs stop at each level with the horizontal framing bearing on top of the stud assembly.
http://be.linkedin.com/in/fusionpoint
Mike McCann, PE, SE (WA)
Since wood shrinks more, percentage-wise, in the radial and tangential directions (vs. the longitudinal direction) you have sometimes somewhat significant shrinkage in the wall from these flat-oriented members.
By using balloon framing you eliminate these flat members and reduce the total shrinkage.
I'm not a French speaker, but other sources translate 'boulin' to mean 'ledger,' which makes sense to me.
