Sound Insulation Testing Setup?
I'm looking to improve the sound dampening characteristics of a structural panel and would like to build a testing setup to analyze changes made to the panel structure and layering.
The idea is to have a setup that is capable of testing small 12" x 12" sections of paneling.
I'm not really sure where to begin and was hoping I could get a starting point or some design guidelines for an anechoic chamber or test setup that would help me accomplish the above.
After doing a little digging and looking for some testing setups, I was thinking of building a small cube made of the panel material. There would be a sound source inside and a sound measuring device outside. Would this be an acceptable DIY setup? Would it be better to perform such a test within an anechoic chamber?
RE: Sound Insulation Testing Setup?
TTFN (ta ta for now)
ASTM E1222 - 90(2016)
Standard Test Method for Laboratory Measurement of the Insertion Loss of Pipe Lagging Systems
ASTM E90 - 09(2016)
Standard Test Method for Laboratory Measurement of Airborne Sound Transmission Loss of Building Partitions and Elements
ASTM E1289 - 08(2016)
Standard Specification for Reference Specimen for Sound Transmission Loss
ASTM E336 - 16a
Standard Test Method for Measurement of Airborne Sound Attenuation between Rooms in Buildings
Walt
The idea or goal of these tests is to come up with the optimal material and layering configuration to reduce noise.
There is some baseline data for a current panel. A sample panel using the same configuration would be created to fit the testing rig, and it would be optimized from there. The final full scale product will be sent out to a laboratory for official testing and to gather actual data.
Cheers
Greg Locock
My point is, for assessment of design changes it is usually faster (and cheeper) to play around with a numerical model than building and testing various physical models. Then, after narrowing in on the best configurations, you can build and test one or more for real-world/lab data.
