modal participation factor
Any body can explain :
1. what is modal participation factor
2. how is it used
3. how to calculate it
4. good/simple book that detailed modal participation factor.
Thnaks in advance.
eka
RE: modal participation factor
Which doesn't mention it, sadly.
This pretty much answers your questions:
http://femci.gsfc.nasa.gov/presentations/UAI990304.pdf
It was the 5th hit on google. I strongly suggest you learn to use a search engine before asking here. Some of us are very grumpy bears.
Cheers
Greg Locock
the modal participation measures the coupling between the exciting force and the given mode shape.
for example, if you have a uniformly distributed excitation force and you want a quantifiable measure of the coupling to each of you modes then modal participation is proportional to the integral of (force) x (mode shape). normalization insures that the maximum value is unity.
Thompson or Weaver are good starting points
