Ethylene Pumping Requirements
Hello, I am new to Eng Tips and was hoping to get some guidance regarding the pumping of ethylene. The fluid would enter the pump from a pipeline at suction pressure of 1600 psi and at 60-70F. My phase diagram shows that this fluid will be supercritical, which I recall, will have both liquid and gas characteristics. So here's my question: can I use a pump or do I need a compressor? If a pump can be used, what type of pump is needed and what special features would it have to have?
Thanks!
Under Pressure
Thanks!
Under Pressure
RE: Ethylene Pumping Requirements
