CFPS and new CWBSD
CFPS and new CWBSD
I am sure this has been asked on here before, but has anybody ever taken the CFPS test, and are there any advantages to it? Now that I passed my NICET Level III testing, the CFPS was next on my list of goals. I didn't know if it was worth the time and money or not though?
Also, I got on NFPA's website today, to look at the CFPS information, and I see this: COMING SOON! Certified Water-Based Systems Designer (CWBSD)
Has anybody heard anything about this? Seeing it on their website this morning is the first I have heard anything about it!
RE: CFPS and new CWBSD
I had heard of the CWSBD by NFPA. I have a colleague who has mentioned that he is on the planning committee for it. But, he has not been able to say anything more about it than that. I am interested in seeing how that takes off. I will likely obtain that when it is available.
As a fire sprinkler system design guy for nearly 30 years, I can say the NICET IV has been the most beneficial of what I have done. I was working toward the Masters in FPE. The program I was in was divided into application and theory. The application part was relatively easy. The theory part was way over my head. I have not had calculus in over 20 years and there was a lot of differential eq math in that part of the program. I would still love to go back and finish. My bachelors degree is in a science field, but not an engineering field. My goal was to get the MS FPE and then be able to sit directly for the FPE exam. I have met the qualifications in states where I am concerned to sit for the Fundamentals of Engineering (FE) exam. However, the general aspect of that test would drop me. I have reviewed many practice tests and prep books. I would need to take a 2 year hiatus from work to be able to pass that FE exam without the engineering degree and just going over the material to a degree I could be competent enough to pass.
So, after all of that, don't waste your time on CFPS unless you are wanting to do something broader than fire sprinkler system layout.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
The CFPS, like Travis said, is how fast you can look up info in the NFPA fire protection handbooks. I don't want to sound harsh but Ctrl+F can do the same thing in the .pdf of the texts.
Today I see so much alphabet soup behind people's names I don't know what 90% of it even means. I would suggest keeping on and getting your NICET IV.
I too am interested in the NFPA cert. I have a NICET III water based and PE but wonder what's in store for this new certification. Even with my credentials there is so much to learn about fire protection in general it makes my head spin.
PS I plan to take the NICET IV CBT this fall [I can't use passing an exam for CPD points until then!]
Yeah, I used to think I wanted to pursue the CFPS, but now I am thinking I will skip it. This new CWBSD has me intrigued though. And I agree, I am going to keep at it and get level IV, but I need to with 5 years, to meet the experience requirement, I do believe. Good luck on your Level IV test. I am sure you got this, but if there is anything we can do to help, just holler! And prehaps after you do it, you could let us know what it like?
I took my exams under the WE format. Now it looks like there are OSHA and CFR regulations in there to study in addition to the typical layout knowledge. I was a single element [cooling towers] away from Level IV years ago but took the FE exam instead. Both FE and NICET exams were on the same day but my school offered to pay for the FE so I went that route.
It looks like now you can schedule the exam any time with a testing center. That sounds nice. It used to be on Saturdays only and many had to get hotel rooms or wake up extra early to have enough drive time to arrive at the test site.
The scheduling is pretty convenient. They let you know what days/times they have open, and you pick what you want. The Level IIIB test was 4 hours, and the only start times I was given as a choice were 8 am. With the IV test being almost 5 hours, I would think you would be looking at something similar.
