ReUse Library
ReUse Library
ReUse Library
I created a sketch for a simple bent bracket then extruded it. Then I added the sketch and the extrusion to the Reuse Library.
What is the freaking secret to adding it to a new file in the position you want it to come in?
No matter what I select. the bracket will come in flipped in a different direction than I want it. I noticed that when I am trying to select a surface of another body to place it, the dynamic WCS in the preview window will jump around as well. Why wont these things just get placed like components do? Why make this so confusing?
NX11 if it matters on this
