contact interaction
contact interaction
contact interaction
hello all,
usually friction value is given as input to abaqus when two material are in contact
Is there we can define some other parameters instead friction and taking friction as a output from abaqus
RE: contact interaction
I don't think so.
If you know the forces and want to get the corresponding friction, then you could use iSight to do a parameter optimization on the friction to find the value that matches the forces.
